Is there a efficient way to reduce computation time in structures connected with long pipes? Trying to model a system with large chambers connected by 300 m of 0.25 m pipe with periodic pump ports.
Thanks, Jon
Thanks, Jon
Hello Jon,
Yes and no... well, the particles have to do the random walk through the long thin pipes, which will always take a long time.
You could, maybe, use periodic boundary conditions instead of modeling the whole periods of long pipe/pump assemblies, but if I understand your description correctly, that wouldn't work either because your system is not infinite (but the large pipes are only connecting large tanks).
You could, however do a trick, but it's pretty advanced and prone to errors. I demonstrate it below. Say you have a system with two large volumes connected by a long pipe:
You can isolate the pipe+pump assembly and launch particles from one, then the other side of the pipe, while keeping the pumping speeds:
On this screenshot (right click+open image for full size) you can see that ~98% of particles come back to the first volume, 1.4% gets pumped and 0.73% goes through.
You should repeat the same launching particles from the other side if the pipe is not symmetric.
Then with this precalculated 97.9% return, 1.4% pumping and 0.7% crossing rate you can simplify your system:
(I moved the cubes closer but it's not necessary, they will be connected by "teleports").
Instead of the long pipe and pump, I use a succession of 3 circular facets at the opening (0.001cm away, so that particles don't leak between them):
1) First facet with 98% opacity (will turn back 98% of the particles, just like the long tube)
2) Second facet that teleports to the next cube, with opacity=0.36 (36% of the remaining 2% of particles will be teleported to the next cube, which equals 0.73% just like in the original system)
3) Third facet with sticking=1 (the rest, or 1.4% will be pumped)
Then you do the same on the other cube.
There are a few tricks when setting up the teleports (the facets have to be two-sided and facing the same direction), as described here. I've also added a reflective collar around the three circular facets to prevent particles leaking out between them.
Here are the three stages:
original system.zip
pipe analysis.zip
simplified equivalent.zip
The result is very fast (no pipe at all to traverse) but setting it up is labor-intensive. In the end, you have to find a good balance between your time (which is expensive) and computation time (which is cheap) :) If you have the same long pipe (300m and 0.25 diam), then one precalculation is enough. Good luck!
