Applying Texture, Molflow 2.9.17
I’m currently trying to add texture properties and texture scaling to a complex (>100000 facets) imported geometry and when I attempt to do so and hit apply, seemingly nothing happens when I run the simulation. When I enter Advanced Facet Parameters after, the texture properties section is greyed out but still lists all the options I had entered beforehand. Do you know what the cause of this is and what I can potentially do to fix this? Also, facet numbers do not show up for me in the lower right corner of the screen.
Thank you!
I’ll reply next week, Cern is closed this week. Thanks for your patience.
Thank you, Marton. Any updates on this?
Can you attach a minimal working example for this bug, if possible, with steps to reproduce? Thank you.
