Hello!Marton teacher
I would like to know that in addition to setting the transient air output rate, can I also set the pumping speed to drop to 0 within a certain period of time?
Write a parameter name, for example “pump_t” as sticking factor on the facet representing the pump
Define the time-dependent parameter “pump_t” in parameter editor
Note that you can only assign a time-dependent sticking, not time-dependent outgassing, but they are convertible: Pumping_speed [l/s] = sticking * A[cm2] * 11.77[l/s/cm2]
for room-temperature nitrogen, or Pumping_speed[m3/s] = sticking * 0.25 * molecule_speed[m/s] * A[m2]
for other gases. A is facet area, molecule_speed is average molecule speed.
We have used this method before to simulate turning on a pump, it looks kind of cool:
