"Copy All" popup doesn't copy when UI Scale <> 1
I recently had to set the UI scale to less than 1 because my memorized selection list got too long. However, when the UI scaling is anything other than 1 the Copy All popup on a right mouse click will not copy the data from whatever window you are doing it in. In my case I do this a lot for the Vertices List, as I have a special spreadsheet that calculates different lengths, diameters, and etc… You can see that the “Copy All” stays grayed out. I tested for different user scales and it only work if it is set to 1. I’m using version 2.11.0 for MacOS.
Thank you for reporting this!
I think it’s not only Copy All, but all the right-click menus in tables and plotters.
In fact, the menus still work, but I think reading cursor coordinates is the problem. If I scale to 0.9 and open a menu, I need to hover the mouse slightly to the right and slightly below the menu option I want, and then it becomes blue and can be clicked. I will check how it can be fixed of course, this is just a temporary “hack” you can use in the meantime if scaling is crucial for your case.
Petar
Actually, I just remembered and verified - this problem was already solved and it works well since version 2.11.1, so hopefully you can switch to this one.
