I like the feature to export selected facets. Would it be possible to export them as a .stl file? As of now they are only exported as .geo. many thanks
Hello Keng-Pei,
As STL format doesn't support polygons (only triangles), this is unfortunately not possible.
Marton
Thanks for the quick reply
If my file started as .stl, and I didn't combine or collapse any points when it is imported, would this keep it purely triangle and safe for .stl export?
Hello Keng-Pei,
Yes, if the original file wasn't collapsed, exporting it in STL again could work. But it needs time to write this new function, and many geometry editors already do this. So I was wondering: what exactly are you trying to achieve? Why don't you save he parts as geo files?
You are right, I've tested several 3D model editing tool and did find a couple that do the job. Thanks.
