I would like to know the meaning of “1” in the Impingement rate and particle density in the figure. Does the “1” mean the number of particles if I understand correctly?
Lee
Lee
Exactly, in both cases 1 is particles.
Imp.rate: particle_hits/second/m2
Density: particles/m3
Just to confirm I am interpreting this right. I am using the formula editor to track impinging rate on a facet (formula Z100). This should give the particle_hits/sec/m^2, so to estimate the total number of particles that hit the facet each second I need to multiply by the area of the facet. However, I’m assuming the area of a facet is calculated in units of cm^2 when using the formula editor. So to get the particle_hits/sec the formula should look like this:
Z100*(AR100/1e4)
I realize this is a basic question, but the units of imp. rate and area are not explicitly listed in the formula editor syntax guide, so I would just like to confirm this is correct.
Hi Joey
Yes, that is correct!
The units of impingement rate and area are the same in the formula editor as elsewhere (hits/sec/m^2 for impingement, cm^2 for area). The same goes for other formula variables as well.
