Molflow crashes using a reloaded xml file with simulation results
I've get two kinds of crashes after I've reloaded a larger (67MB) xml file which has simulation data results in it. I don't get crashes on smaller files (6MB). The first is a crash when trying to open the file; this has only happened once. The rest of the time it always crashes when I open the texture scaling dialog box and change it from showing the default pressure value to either impingement or density. I also tried resetting the simulation first, but it still crashes when changng from pressure.
Once again, if you could share with me the file, I'd have a look and try to reproduce the bug. Thank you.
Hello!
I’m using Molflow 2.9.3 (beta) (released January 31, 2022).
Molflow 2.9.3 (beta) crashes when running “Create two facets > Difference> Auto (non-zero)”. Help to understand the cause of the crash: Incorrect use of the command or failure?
Attached is a link to the repository with the file and screenshots.
test pressure indicator on time scale 2
Hey Alexej,
I could recreate this issue and I’ll be working on a fix ASAP. Once it’s published, I’ll let you know.
Pascal
