Molflow installation
I get on my MacPro M1, Sequoia 15.1.1
Library not loaded: /usr/local/opt/libomp/lib/libomp.dylib
don’t see the file anywhere Thanks
Hello Stefano,
Are you sure that you installed OpenMP (see instructions)?
Thank Marton, In the instructions I don’t see any reference to OpenMp only to homebrew
that I did. The problem seems that my Mac wants a x86_64 lib and that it’s not installed. Could that be?
Are you sure you downloaded the ARM, not the Intel version of Molflow?
Otherwise I recommend to update to the latest macOS, and try again.
If that doesn’t work either, you can build from source, if you have the experience, or search for the exact error message you receive. (I tested Molflow on an M1 mac successfully now.)
mmm, I’m almost certain. Anyway should I start again: update, download arm, redo the procedure? Probably the best option, right?
Thanks
If you want to use the mac version, then yes, i’d do that.
Sorry that I can’t help more, as Apple doesn’t allow macOS to run on anything but Apple hardware, we can only do ad-hoc tests on our laptops.
thanks anyway, I’ll let you know the outcome
Success! Thanks a lot
