Hello there,
I have been doing some more simulations on molflow+ simulating simple cylindrical vacuum chambers. Pump on one end, outgassing on other. I have been taking some time to do some benchmarking against published papers to make sure i’m setting up the simulations right. I came across this paper “New time-dependent simulations with the test particle monte carlo code MOLFLOW+” by Ady et al. and used the problem detailed in the time-dependent simulations section to check my setup.
It turns out my setup was correct, but i’ve come into some interesting behavior when using the equations attached (they came directly from the paper.) The graph bellow the equations is the exact simulation detailed in the paper and the MOLFLOW+ result checks out pretty much perfectly.
I was playing around with the same setup and increased only the length of the pipe, therefore increasing the conductance of the pipe. I was checking the simulation results with a calculator i setup using the equations and suddenly there is a large jump in pressure at the moment gas is turned off (t = 0.02 s). Are the equations not good for higher conductance pipes or is there something fundamental i’m missing here?
Thanks for the assistance ahead of time!
