Smart Selection is not working in version 2.9.19. I also see it has problems cycling through all facets that are under the mouse when you do a normal selection. I opened the same model in 2.9.18 and Smart Section works fine. I also tried it out on a simple test cylinder and see the exact same behavior. I’m running it on Sonoma macOS ARM.
Hello Alan.
I unpublished 2.9.19, because indeed the Smart Select was disabled by a missing () in a logical condition.
I’ll see about the cycling issue (a complex and hard to debug parallel-computed routine), and when reliable again, I’ll publish 2.9.20.
Marton
I have released 2.9.21 today, where I tested extensively and the selection seems to work as expected. Let me know if you run into issues and thanks for the report
Thanks, I’ll give it test!
