Hello everyone,
I am trying to understand how the different physical quantities in Molflow are interconnected—specifically density, pressure, impingement rate, and speed. I am finding inconsistencies that I cannot fully explain.
If I manually try to compute the impingement rate using:
flux = density × speed
the result does not match the impingement-rate plot shown by Molflow.
In my simulation the beam divergence is extremely narrow (≈7 mrad), and I am using the molecular speed directly from the Molflow “calculated profile” for our beam at the target surface. Our physical setup uses a two-stage cascaded capillary tube to obtain a highly collimated helium beam. In Molflow, the beam looks correct—collimated and narrow—but the numerical outputs confuse me.
My questions are:
Which speed does Molflow internally use for converting density → flux and density → pressure?
(thermal speed, injected beam speed, or something else?) -
How exactly does Molflow compute pressure from density?
Why does the impingement rate shown in the facet results not match the value obtained from “density × speed,” even for a nearly parallel beam with very small divergence?
Do the angular distribution and Monte-Carlo weighting influence the averaged speed that Molflow uses?
A brief clarification on these relationships would really help me correctly interpret the simulation outputs.
Thank you very much.
Saurabh
Output beam profile at target surface (in density):
Output beam profile at target surface (in pressure unit):
Output beam profile at target surface (in m/s, speed):
