Dear Sir,
I checked the following documents given by CERN:
Molflow+ tutorial
‘R. Kersevan, M. Ady Vacuum, Surfaces and Coatings Group, Technology Department
CERN, Geneva (CH)
(more on http://test-molflow.web.cern.ch/ ! Molflowdocumentation!AVS-61)’
When I tried for time dependent molflow and executed injection and pump down using parameter given by this documents. Pressure shows very high however the pressure plot of the documents show low pressure. I can not understood where is the problem. Kindly help me out from it.
Thanking You
Regards
Sabbir
