Hi
I have been playing with MolFlow for some time and I have to admit that I do not understand the results. I do have a set of simulation results that were obtained using the Monte Carlo solver in ANSYS and were benchmarked against the
results published by F. Sharipov, but I do have a problem with interpretation of the Molflow results.
To limit this enquiry to a simple pipe test case:
It looks like that the pressure distribution is independent of the volume flow rate. As there are no units in the pressure distribution Molflow is presenting, my suspicion is that some normalisation takes place. Can you please explain?
For the inlet, it seems that the outgassing values do not affect the results. What is the mathematical expression behind?
The volumetric pumping speed produces a sticking factor value that is too low. This may be an incorrect statement, but in absence of any mathematical formulations, I can only
compare the values with the values from other sources. -
Can you please explain, for the test cases that are available with the package, what are anticipates results and more importantly, how they are defined.
Thank you very much for your help.
Kind regards, Andrej
