I am trying to import an STL file into Molflow+ 2.9.4 (beta) and it is consistently coming up with the error “Wrong integer format (line 2).”
The file is in ASCII format so that is not the issue, I have tried playing around with the numbers on line 2, removing scientific notation etc. and the issue still persists.
Edit: This bug persists for both “load” and “Insert”
Please check with the latest version, 2.9.6: Releases · molflow_synrad / molflow · GitLab
Although this is not likely to solve the issue, as I don’t remember changing STL loading recently.
If still the same, please let me know which OS you’re on, and, if not confidential, attach the file here (or send by private message) and I’ll take a look.
